Nokia XL Spare Parts
Browse Spare Parts for Nokia XL
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Nokia XLweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Nokia XL
CAD 34.99  $45.99'Not yet rated.'Out of StockAdd weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Nokia XL to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Nokia XLweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Nokia XL
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Nokia XL to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Nokia XLweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Nokia XL
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Nokia XL to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Nokia XLweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Nokia XL
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Out of StockAdd weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Nokia XL to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Nokia XLweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Nokia XL
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Nokia XL to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Nokia XLweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Nokia XL
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Nokia XL to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for Nokia XLweBoost NMO Antenna 800/1900 MHz Omni Directional for Nokia XL
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost NMO Antenna 800/1900 MHz Omni Directional for Nokia XL to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Nokia XLweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Nokia XL
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Nokia XL to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Nokia XLweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Nokia XL
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Nokia XL to Cart
weBoost Marine Antenna Mount (901119) for Nokia XLweBoost Marine Antenna Mount (901119) for Nokia XL
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for Nokia XL to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Nokia XLweBoost Suction Cup Window Mount for Magnet Antennas (901128) for Nokia XL
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Nokia XL to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Nokia XLweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Nokia XL
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Nokia XL to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Nokia XLweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Nokia XL
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Nokia XL to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Nokia XLweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Nokia XL
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Nokia XL to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Nokia XLweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Nokia XL
CAD 39.99  $49.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Nokia XL to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Nokia XLweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Nokia XL
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Out of StockAdd weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Nokia XL to Cart
weBoost DC 12v Hardwire Power Kit for Nokia XLweBoost DC 12v Hardwire Power Kit for Nokia XL
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for Nokia XL to Cart
weBoost DC/DC 6 volt Power Supply for Nokia XLweBoost DC/DC 6 volt Power Supply for Nokia XL
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for Nokia XL to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Nokia XLweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Nokia XL
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Nokia XL to Cart
weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Nokia XLweBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Nokia XL
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Nokia XL to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Nokia XLweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Nokia XL
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Nokia XL to Cart
weBoost Home Accessory Kit for Sleek Amp for Nokia XLweBoost Home Accessory Kit for Sleek Amp for Nokia XL
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for Nokia XL to Cart
weBoost Battery Pack for Nokia XLweBoost Battery Pack for Nokia XL
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for Nokia XL to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Nokia XLweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Nokia XL
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Nokia XL to Cart
weBoost Adjustable Suction Cup Mount for Nokia XLweBoost Adjustable Suction Cup Mount for Nokia XL
CAD 23.99  $27.99'Not yet rated.'Out of StockAdd weBoost Adjustable Suction Cup Mount for Nokia XL to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Nokia XLweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Nokia XL
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Nokia XL to Cart
weBoost 4G-X OTR Drive Kit for Nokia XLweBoost 4G-X OTR Drive Kit for Nokia XL
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for Nokia XL to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Nokia XLweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Nokia XL
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Nokia XL to Cart
Accessories
Customer Care
Powered by...
Our Customers Say...
