Microsoft Surface Pro 2 Spare Parts
Browse Spare Parts for Microsoft Surface Pro 2
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Microsoft Surface Pro 2weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Microsoft Surface Pro 2
CAD 34.99  $45.99'Not yet rated.'Ships 3/29Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Microsoft Surface Pro 2 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Microsoft Surface Pro 2weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Microsoft Surface Pro 2
CAD 29.99  $32.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Microsoft Surface Pro 2 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Microsoft Surface Pro 2weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Microsoft Surface Pro 2
CAD 29.99  $35.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Microsoft Surface Pro 2 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Microsoft Surface Pro 2weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Microsoft Surface Pro 2
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 3/29Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Microsoft Surface Pro 2 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Microsoft Surface Pro 2weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Microsoft Surface Pro 2
CAD 34.99  $44.99'Not yet rated.'Ships 3/29Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Microsoft Surface Pro 2 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Microsoft Surface Pro 2weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Microsoft Surface Pro 2
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 3/29Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Microsoft Surface Pro 2 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for Microsoft Surface Pro 2weBoost NMO Antenna 800/1900 MHz Omni Directional for Microsoft Surface Pro 2
CAD 19.99  $26.99'Not yet rated.'Ships 3/29Add weBoost NMO Antenna 800/1900 MHz Omni Directional for Microsoft Surface Pro 2 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Microsoft Surface Pro 2weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Microsoft Surface Pro 2
CAD 11.90'Not yet rated.'Ships 3/29Add weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Microsoft Surface Pro 2 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Microsoft Surface Pro 2weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Microsoft Surface Pro 2
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Microsoft Surface Pro 2 to Cart
weBoost Marine Antenna Mount (901119) for Microsoft Surface Pro 2weBoost Marine Antenna Mount (901119) for Microsoft Surface Pro 2
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for Microsoft Surface Pro 2 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Microsoft Surface Pro 2weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Microsoft Surface Pro 2
CAD 9.99  $9.99'Not yet rated.'Ships 3/29Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Microsoft Surface Pro 2 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Microsoft Surface Pro 2weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Microsoft Surface Pro 2
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Microsoft Surface Pro 2 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Microsoft Surface Pro 2weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Microsoft Surface Pro 2
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Microsoft Surface Pro 2 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Microsoft Surface Pro 2weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Microsoft Surface Pro 2
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Microsoft Surface Pro 2 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Microsoft Surface Pro 2weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Microsoft Surface Pro 2
CAD 39.99  $49.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Microsoft Surface Pro 2 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Microsoft Surface Pro 2weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Microsoft Surface Pro 2
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 3/29Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Microsoft Surface Pro 2 to Cart
weBoost DC 12v Hardwire Power Kit for Microsoft Surface Pro 2weBoost DC 12v Hardwire Power Kit for Microsoft Surface Pro 2
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for Microsoft Surface Pro 2 to Cart
weBoost DC/DC 6 volt Power Supply for Microsoft Surface Pro 2weBoost DC/DC 6 volt Power Supply for Microsoft Surface Pro 2
CAD 37.99  $48.99'Not yet rated.'Ships 3/29Add weBoost DC/DC 6 volt Power Supply for Microsoft Surface Pro 2 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Microsoft Surface Pro 2weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Microsoft Surface Pro 2
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Microsoft Surface Pro 2 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Microsoft Surface Pro 2weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Microsoft Surface Pro 2
CAD 19.99  $26.99'Not yet rated.'Ships 3/29Add weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Microsoft Surface Pro 2 to Cart
weBoost Home Accessory Kit for Sleek Amp for Microsoft Surface Pro 2weBoost Home Accessory Kit for Sleek Amp for Microsoft Surface Pro 2
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for Microsoft Surface Pro 2 to Cart
weBoost Battery Pack for Microsoft Surface Pro 2weBoost Battery Pack for Microsoft Surface Pro 2
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for Microsoft Surface Pro 2 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Microsoft Surface Pro 2weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Microsoft Surface Pro 2
CAD 35.99  $35.99'Not yet rated.'Ships 3/29Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Microsoft Surface Pro 2 to Cart
weBoost Adjustable Suction Cup Mount for Microsoft Surface Pro 2weBoost Adjustable Suction Cup Mount for Microsoft Surface Pro 2
CAD 23.99  $27.99'Not yet rated.'Ships 3/29Add weBoost Adjustable Suction Cup Mount for Microsoft Surface Pro 2 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Microsoft Surface Pro 2weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Microsoft Surface Pro 2
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Microsoft Surface Pro 2 to Cart
weBoost 4G-X OTR Drive Kit for Microsoft Surface Pro 2weBoost 4G-X OTR Drive Kit for Microsoft Surface Pro 2
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 3/29Add weBoost 4G-X OTR Drive Kit for Microsoft Surface Pro 2 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Microsoft Surface Pro 2weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Microsoft Surface Pro 2
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Microsoft Surface Pro 2 to Cart
Accessories
Customer Care
Powered by...
Our Customers Say...
