Lumia 950 Spare Parts
Browse Spare Parts for Lumia 950
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 950weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 950
CAD 34.99  $45.99'Not yet rated.'Ships 3/30Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 950 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 950weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 950
CAD 29.99  $32.99'Not yet rated.'Ships 3/30Add weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 950 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 950weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 950
CAD 29.99  $35.99'Not yet rated.'Ships 3/30Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 950 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 950weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 950
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 3/30Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 950 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 950weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 950
CAD 34.99  $44.99'Not yet rated.'Ships 3/30Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 950 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 950weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 950
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 3/30Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 950 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 950weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 950
CAD 19.99  $26.99'Not yet rated.'Ships 3/30Add weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 950 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 950weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 950
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 950 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 950weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 950
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 950 to Cart
weBoost Marine Antenna Mount (901119) for Lumia 950weBoost Marine Antenna Mount (901119) for Lumia 950
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for Lumia 950 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 950weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 950
CAD 9.99  $9.99'Not yet rated.'Ships 3/30Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 950 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 950weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 950
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 950 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 950weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 950
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 950 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 950weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 950
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 950 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 950weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 950
CAD 39.99  $49.99'Not yet rated.'Ships 3/30Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 950 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 950weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 950
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 3/30Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 950 to Cart
weBoost DC 12v Hardwire Power Kit for Lumia 950weBoost DC 12v Hardwire Power Kit for Lumia 950
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for Lumia 950 to Cart
weBoost DC/DC 6 volt Power Supply for Lumia 950weBoost DC/DC 6 volt Power Supply for Lumia 950
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for Lumia 950 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 950weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 950
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 950 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 950weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 950
CAD 19.99  $26.99'Not yet rated.'Ships 3/30Add weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 950 to Cart
weBoost Home Accessory Kit for Sleek Amp for Lumia 950weBoost Home Accessory Kit for Sleek Amp for Lumia 950
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for Lumia 950 to Cart
weBoost Battery Pack for Lumia 950weBoost Battery Pack for Lumia 950
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for Lumia 950 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 950weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 950
CAD 35.99  $35.99'Not yet rated.'Ships 3/30Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 950 to Cart
weBoost Adjustable Suction Cup Mount for Lumia 950weBoost Adjustable Suction Cup Mount for Lumia 950
CAD 23.99  $27.99'Not yet rated.'Ships 3/30Add weBoost Adjustable Suction Cup Mount for Lumia 950 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 950weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 950
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 950 to Cart
weBoost 4G-X OTR Drive Kit for Lumia 950weBoost 4G-X OTR Drive Kit for Lumia 950
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 3/30Add weBoost 4G-X OTR Drive Kit for Lumia 950 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 950weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 950
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 950 to Cart
Accessories
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
