Lumia 650 Spare Parts
Browse Spare Parts for Lumia 650
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 650weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 650
CAD 34.99  $45.99'Not yet rated.'Out of StockAdd weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 650 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 650weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 650
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 650 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 650weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 650
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 650 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 650weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 650
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Out of StockAdd weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 650 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 650weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 650
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 650 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 650weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 650
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 650 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 650weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 650
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 650 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 650weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 650
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 650 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 650weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 650
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 650 to Cart
weBoost Marine Antenna Mount (901119) for Lumia 650weBoost Marine Antenna Mount (901119) for Lumia 650
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for Lumia 650 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 650weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 650
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 650 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 650weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 650
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 650 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 650weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 650
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 650 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 650weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 650
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 650 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 650weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 650
CAD 39.99  $49.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 650 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 650weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 650
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Out of StockAdd weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 650 to Cart
weBoost DC 12v Hardwire Power Kit for Lumia 650weBoost DC 12v Hardwire Power Kit for Lumia 650
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for Lumia 650 to Cart
weBoost DC/DC 6 volt Power Supply for Lumia 650weBoost DC/DC 6 volt Power Supply for Lumia 650
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for Lumia 650 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 650weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 650
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 650 to Cart
weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 650weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 650
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 650 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 650weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 650
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 650 to Cart
weBoost Home Accessory Kit for Sleek Amp for Lumia 650weBoost Home Accessory Kit for Sleek Amp for Lumia 650
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for Lumia 650 to Cart
weBoost Battery Pack for Lumia 650weBoost Battery Pack for Lumia 650
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for Lumia 650 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 650weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 650
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 650 to Cart
weBoost Adjustable Suction Cup Mount for Lumia 650weBoost Adjustable Suction Cup Mount for Lumia 650
CAD 23.99  $27.99'Not yet rated.'Out of StockAdd weBoost Adjustable Suction Cup Mount for Lumia 650 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 650weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 650
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 650 to Cart
weBoost 4G-X OTR Drive Kit for Lumia 650weBoost 4G-X OTR Drive Kit for Lumia 650
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for Lumia 650 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 650weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 650
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 650 to Cart
Accessories
Customer Care
Powered by...
Our Customers Say...
