Lumia 640 Spare Parts
Browse Spare Parts for Lumia 640
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 640weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 640
CAD 34.99  $45.99'Not yet rated.'Ships 5/8Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for Lumia 640 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 640weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 640
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for Lumia 640 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 640weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 640
CAD 29.99  $35.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for Lumia 640 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 640weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 640
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 5/8Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for Lumia 640 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 640weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 640
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for Lumia 640 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 640weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 640
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for Lumia 640 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 640weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 640
CAD 19.99  $26.99'Not yet rated.'Ships 5/8Add weBoost NMO Antenna 800/1900 MHz Omni Directional for Lumia 640 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 640weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 640
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for Lumia 640 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 640weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 640
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for Lumia 640 to Cart
weBoost Marine Antenna Mount (901119) for Lumia 640weBoost Marine Antenna Mount (901119) for Lumia 640
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for Lumia 640 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 640weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 640
CAD 9.99  $9.99'Not yet rated.'Ships 5/8Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for Lumia 640 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 640weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 640
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for Lumia 640 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 640weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 640
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for Lumia 640 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 640weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 640
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for Lumia 640 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 640weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 640
CAD 39.99  $49.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for Lumia 640 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 640weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 640
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 5/8Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for Lumia 640 to Cart
weBoost DC 12v Hardwire Power Kit for Lumia 640weBoost DC 12v Hardwire Power Kit for Lumia 640
CAD 9.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for Lumia 640 to Cart
weBoost DC/DC 6 volt Power Supply for Lumia 640weBoost DC/DC 6 volt Power Supply for Lumia 640
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for Lumia 640 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 640weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 640
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for Lumia 640 to Cart
weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 640weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 640
CAD 9.99  $9.99'Not yet rated.'Ships 5/8Add weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for Lumia 640 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 640weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 640
CAD 19.99  $26.99'Not yet rated.'In StockView weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for Lumia 640 Options
weBoost Battery Pack for Lumia 640weBoost Battery Pack for Lumia 640
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for Lumia 640 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 640weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 640
CAD 35.99  $35.99'Not yet rated.'Ships 5/8Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for Lumia 640 to Cart
weBoost Adjustable Suction Cup Mount for Lumia 640weBoost Adjustable Suction Cup Mount for Lumia 640
CAD 23.99  $27.99'Not yet rated.'Ships 5/8Add weBoost Adjustable Suction Cup Mount for Lumia 640 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 640weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 640
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for Lumia 640 to Cart
weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for Lumia 640weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for Lumia 640
Stay connected as you drive with the WeBoost 3G-S Drive signal booster kit. Designed for easy install, the 3G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on Canada's major networks with the Drive 3G-S. Boosts voice and 3G services. This product is covered by a 2 year warranty which we assume on behalf of the manufacturer.
Free Shipping
CAD 144.99  $149.99'Not yet rated.'Ships 5/8Add weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for Lumia 640 to Cart
weBoost 4G-S Drive Kit for Lumia 640weBoost 4G-S Drive Kit for Lumia 640
Stay connected as you drive with the WeBoost 4G-S Drive signal booster kit. Designed for easy install, the 4G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on all Canadian networks with the Drive 4G-S. Boosts voice, 3G, and 4G services.
Free Shipping
CAD 264.99  $269.99'Not yet rated.'Pre-OrderAdd weBoost 4G-S Drive Kit for Lumia 640 to Cart
weBoost 4G-M Drive Kit for Lumia 640weBoost 4G-M Drive Kit for Lumia 640
Multiple users can stay connected as you drive, with the WeBoost 4G-M Drive signal booster kit. Designed for easy install, the 4G-M Drive keeps your phone, and others, connected to cell sites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and speed up data speeds on Canada's major networks with the Drive 4G-M. Boosts voice, 3G, and 4G services.
Free Shipping
CAD 574.99  $579.99'Not yet rated.'Pre-OrderAdd weBoost 4G-M Drive Kit for Lumia 640 to Cart
weBoost 3G-X Drive Kit for Lumia 640weBoost 3G-X Drive Kit for Lumia 640
Our most powerful 3G in-vehicle signal booster, the WeBoost 3G-X Drive keeps multiple users connected on the road. Designed for easy install, the 3G-X Drive keeps your phone, and others, connected to cellsites in remote, low-signal locations. Reduce dropped calls, maximize your coverage area and improve data speeds on Canada's major networks with the Drive 3G-X. Boosts voice and 3G services.
Free Shipping
CAD 599.99  $604.99'Not yet rated.'Ships 5/8Add weBoost 3G-X Drive Kit for Lumia 640 to Cart
weBoost 3G-Flex Drive Kit for Lumia 640weBoost 3G-Flex Drive Kit for Lumia 640
Need a signal booster that can travel with you? The 3G-Flex Drive signal booster kit can be used in the car, brought inside, or even carried around because it`s powered by USB, DC or AC adapters (all included). Boosts voice and 3G services for multiple phones/devices in a 3 foot radius.
Free Shipping
CAD 294.99  $299.99'Not yet rated.'Ships 5/8Add weBoost 3G-Flex Drive Kit for Lumia 640 to Cart
weBoost 4G Home Kit for Lumia 640weBoost 4G Home Kit for Lumia 640
Stop wandering about your home looking for a better cellphone connection. The WeBoost Home 4G signal booster kit delivers stronger signal for 1-2 rooms in your home, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 654.99  $659.99'Not yet rated.'Ships 5/8Add weBoost 4G Home Kit for Lumia 640 to Cart
weBoost 3G Home Kit for Lumia 640weBoost 3G Home Kit for Lumia 640
Stop wandering about your home looking for a better cellphone connection. The WeBoost Home 3G signal booster kit delivers stronger signal for 1-2 rooms in your home, providing better voice quality and faster internet connection speeds on the major Canadian networks. Boosts voice and 3G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 434.99  $439.99'Not yet rated.'Pre-OrderAdd weBoost 3G Home Kit for Lumia 640 to Cart
weBoost 4G Connect Kit for Lumia 640weBoost 4G Connect Kit for Lumia 640
Bring your building a better cellphone connection. The WeBoost Connect 4G signal booster kit delivers stronger signal for small homes, cabins, or businesses, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 829.99  $834.99'Not yet rated.'Ships 5/8Add weBoost 4G Connect Kit for Lumia 640 to Cart
weBoost 3G-Directional Connect Kit for Lumia 640weBoost 3G-Directional Connect Kit for Lumia 640
Bring your building a better cellphone connection. The WeBoost Connect 3G signal booster kit delivers stronger signal for small homes, cabins, or businesses, providing better voice quality and faster internet connection speeds on the major Canadian networks. Boosts voice and 3G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 654.99  $659.99'Not yet rated.'Pre-OrderAdd weBoost 3G-Directional Connect Kit for Lumia 640 to Cart
weBoost 4G-X Connect Kit for Lumia 640weBoost 4G-X Connect Kit for Lumia 640
Fill your home or business with better cellphone signal. The WeBoost Connect 4G-X signal booster kit delivers stronger signal for large homes and businesses, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
CAD 1,424.99  $1,429.99'Not yet rated.'Ships 5/8Add weBoost 4G-X Connect Kit for Lumia 640 to Cart
weBoost 4G-X OTR Drive Kit for Lumia 640weBoost 4G-X OTR Drive Kit for Lumia 640
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 5/8Add weBoost 4G-X OTR Drive Kit for Lumia 640 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 640weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 640
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for Lumia 640 to Cart
Accessories
Customer Care
Powered by...
Our Customers Say...
