HTC Surround Spare Parts
Browse Spare Parts for HTC Surround
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for HTC SurroundweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for HTC Surround
CAD 34.99  $45.99'Not yet rated.'Out of StockAdd weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for HTC Surround to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for HTC SurroundweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for HTC Surround
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for HTC Surround to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for HTC SurroundweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for HTC Surround
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for HTC Surround to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for HTC SurroundweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for HTC Surround
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Out of StockAdd weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for HTC Surround to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for HTC SurroundweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for HTC Surround
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for HTC Surround to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for HTC SurroundweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for HTC Surround
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for HTC Surround to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for HTC SurroundweBoost NMO Antenna 800/1900 MHz Omni Directional for HTC Surround
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost NMO Antenna 800/1900 MHz Omni Directional for HTC Surround to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for HTC SurroundweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for HTC Surround
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for HTC Surround to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for HTC SurroundweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for HTC Surround
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for HTC Surround to Cart
weBoost Marine Antenna Mount (901119) for HTC SurroundweBoost Marine Antenna Mount (901119) for HTC Surround
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for HTC Surround to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for HTC SurroundweBoost Suction Cup Window Mount for Magnet Antennas (901128) for HTC Surround
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Suction Cup Window Mount for Magnet Antennas (901128) for HTC Surround to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for HTC SurroundweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for HTC Surround
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for HTC Surround to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for HTC SurroundweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for HTC Surround
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for HTC Surround to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for HTC SurroundweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for HTC Surround
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for HTC Surround to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for HTC SurroundweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for HTC Surround
CAD 39.99  $49.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for HTC Surround to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for HTC SurroundweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for HTC Surround
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Out of StockAdd weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for HTC Surround to Cart
weBoost DC 12v Hardwire Power Kit for HTC SurroundweBoost DC 12v Hardwire Power Kit for HTC Surround
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for HTC Surround to Cart
weBoost DC/DC 6 volt Power Supply for HTC SurroundweBoost DC/DC 6 volt Power Supply for HTC Surround
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for HTC Surround to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for HTC SurroundweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for HTC Surround
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for HTC Surround to Cart
weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for HTC SurroundweBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for HTC Surround
CAD 9.99  $9.99'Not yet rated.'Out of StockAdd weBoost Micro-USB Charging Adapter For Sleek / U-Booster Cradle Amplifier for HTC Surround to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for HTC SurroundweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for HTC Surround
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for HTC Surround to Cart
weBoost Home Accessory Kit for Sleek Amp for HTC SurroundweBoost Home Accessory Kit for Sleek Amp for HTC Surround
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for HTC Surround to Cart
weBoost Battery Pack for HTC SurroundweBoost Battery Pack for HTC Surround
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for HTC Surround to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for HTC SurroundweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for HTC Surround
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for HTC Surround to Cart
weBoost Adjustable Suction Cup Mount for HTC SurroundweBoost Adjustable Suction Cup Mount for HTC Surround
CAD 23.99  $27.99'Not yet rated.'Out of StockAdd weBoost Adjustable Suction Cup Mount for HTC Surround to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for HTC SurroundweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for HTC Surround
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for HTC Surround to Cart
weBoost 4G-X OTR Drive Kit for HTC SurroundweBoost 4G-X OTR Drive Kit for HTC Surround
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for HTC Surround to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for HTC SurroundweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for HTC Surround
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for HTC Surround to Cart
Accessories
Customer Care
Powered by...
Our Customers Say...
